Ka24e, , brakes, water pump, coil, silencer.
Due to some financiall issues i need to move some stuff out of the garage, These are all starting price offer me somthing
Ka24e, just over 200000Km on it, pulled strong when removed, Pick up asap $60, i have hoist to put in your car.
Front rotors, factory, $10
Sohc, coil, $10
Brand new water pump $35
3.5" silencer, dual bolt. Brand new, $15
pm, email, call 905-447-2836
alrgiht
clutch and rear rotors and front pads all potentialy sold. If the buyers back out i have pmed the people who are next in line to inform them that they are second in line.
Thanks for the intrest.
Sean
clutch is back up, but dropped to $80.
Sohc, coil, $15
Brand new water pump $40
make me a deal for 40? can you deliver? i got
the money
thanks
Ill give them to you for $50 delivered depending where you are?
Im going to test the coil first because it was never on my car and i would like to verify that it works, It should, but always safe to double check
ignition coil and water pump? $55 no extra parts I’ll think about it.
up, Front brake pads, rear rotors, Gone.
Coil gone.
everything else,
Motor $65
Water pump $35
Clutch$75
Front rotors $10
Silencer $10
I need these out, I will deliver the water pump and clutch
Ill take the clutch if it is for a sohc
Clutch is same for SOHC/DOHC, right? I’ll take it if he backs out for sure.
ill take the silencer i think it might fit my magnaflow exhaust…where are u located?
Im in whitby, Right between oshawa and ajax, About an hour east of T.O,
Let me know.
