hey guys im wondering if i could use my ka24e’s clutch and pressure plate on my s14 ka24de, if anyone knows let me know
It will work. I put a dohc clutch on my Sohc. both peices are exacly the same.
been asked a GAZILLION times…like every week…read posts or search, they are the EXACT same transmission
they are the same Vlad.
So what if it has. It hasn’t been asked that many times that I’ve seen. Simple yes or no, answers his question.
Andrew.
you’re right about how often this question gets asked… although it has nothing to do with the transmission.
You have to be careful what year S14 it is. The later ones (97-8) have a speed sensor in the bellhousing and do not use the same PP. No, it’s not directly related, but there are differences in the pressure plates/flywheels. They’re close, close enough you can mod them to work, but it’s easier to just get the right one. You have to drill out one of the dowel holes a bit larger.
If you have an old KA, you can just mix and match trannies, PPs and flywheels to make it all bolt on.
thanks alot guys, I am planning to use 90 kae clutch/pp on a 95 kade
