high port cams $60
valve cover painted red with gold metal flake there is one small spot where the throttle bracket rubbed other than that its in great condition $30
ecu $40 uncut harness $80
I have a ton of stuff I’m not putting prices on just make an offer if you see something you want, and if you don’t see it just ask
this block is in great shape the engine ran great when I disassembled it wouldn’t need any machine work
no one need any of this stuff? I’ll let it go cheap all the aluminum parts are going to go to the recycler soon
Hey Walt, I could probably use the stock intake and maybe the head if its in good shape (i.e. ready to be bolted on and run as-is).
the intake, and head are in good shape except one exhaust manifold stud is broke, but if you want them I’ll extract it , and helicoil worst case senario
ecu is gone… bump no reasonable offers refused
