can you eat capt’n cruch outta it? if not, then :tdown:
Newman should melt it down and make his grill with it.
cost per piece
about time my pistons got here
Expensive… generally custom pistons start at $100 per hole
new compression???
approx 7.5:1
very perty J :tup:
oohhh titties
:tup:
must be slow with compression that low.
:tup:
:tup: how low is low boost?
5 or 6 psi
gotcha. nuthing higher with those bad boys???
whos pistons are those? damn son
:bsflag: I’m not buying 5-6 psi. Not @ 7.5:1…
Okay maybe 7 psi
i run 8.1 and low boost is 14 psi
Ditto on this one… 7.5:1 @ even 15 PSI is nowhere near detonation threshhold on decent gas. Planning on running fucking 87 or something?
*fixed
