Okay so ive been debating what pistons to run in my bseries motor, combining headgaskets and that.
I was thinking of running n/a this year, and then going boost next year. the thing is, i want to get my car completley done this year as far as motor work and then just be able to turbo it next year, (obv with proper fuel adj. and tuning)
But if i run low compression pistons (like 9.7:1), i calculated the compression using a calculator and my compression was low as fuck and my car would be slow as fuck n/a (yes its a honda, i know):banghead:
Using:
For jdm itr p73-00 pistons w/ stock 81mm bore in a b18c block and a 0.393701inch (1mm) thick headgasket, my compression ratio ended up being
11.17:1 static
Would this be safe for my boost goals? Im guessing prob not…
For the life of me i could not fine the dome of a 84mm 9.7:1 CP Piston, so i just used a 84mm PR4 Piston, which has a -3.2 dome, as opposed to a +5.96 of the itr pistons
For N/A i could run a 1layer gasket, and then when i go boost i could use a 3layer or thicker gasket to help lower my compression
with a “84mm CP Piston” the static was 10.05:1 w/ oem3 layer gasket and 10.4:1 with single layer
I “would” like to make atleast 400wheel…
Either way, im looking to get my block sleeved/gaurd/posts w/e in order to make it safer.
Should i just go with the cp piston, and will it still be fun n/a ?
all values were calculated with 8500rpm limiter
