Selling an LS1 engine removed from a 2000 Corvette 6 speed. 125k miles. Only removed to make room for an LS3 swap. No noises or smoke, ran great when removed. Have video of it on the dyno, message me if you’d like to see that. 363whp and 352 ft-lbs.
Oil was changed every 4-5k using Mobil 1 Synthetic 5W30. The engine is spotless under the valve covers. Totally stock except for replacement valve seals and blue GM LS6 Z06 valve springs. The knock sensors, crank position sensor, and Oil Pressure Sending Unit are new.
The engine is sold as an unopened longblock and includes the Corvette harmonic balancer but no other front accessories.
What it DOESN’T include:
Oil pan
Coil packs
Any wiring harnesses
Power steering pump
Alternator
Corvette Engine Covers (beauty cover)
For ADDITIONAL COST I can include:
LS6 Z06 intake manifold painted wrinkle red.
LS6 PCV system (LS6 valley cover, gasket and bolts)
LS1 fuel rail and injectors
C5 LS1 DBW throttle body
Newer water pump, 25k miles
C5 Corvette iron exhaust manifolds
L92 6.2L “Truck” exhaust manifolds (perfect for your turbo project)
Delivery in WNY area
$2000 OBO, can make a deal for additional items purchased.
Text 716 9 four 9 seven 4 two 4
- Updated - - -
