Comes as pictured.
1997 LS1 block.
2002 Cam.
241 heads.
Fel-Pro head gaskets with 1 year warranty.
Stock 1997 LS1 Intake.
Return style fuel rail - I might have a returnless rail if needed.
28.8 lb injectors.
Ported oil pump.
Coolant cross overs.
Truck oil pan bolted on to keep stuff out.
Valve covers, front cover, and oil pan sand blasted.
Valve covers and front covers gloss black in high temp paint.
Less then 50K miles on set up.
The intake manifold, rail and injectors are just sitting on the engine I misplaced the bolts.
Any questions please feel to ask.
Thanks if someone wanted to do drive by wire I have a ported corvette throttle body I could bolt on as well for $100.
I can get compression numbers if needed.
$1200 obo.
