I have a 34,xxx mile cammed LS1 engine available for sale here: http://www.nyspeed.com/showthread.php?282656-LS1-Engine-with-Cam-34656-miles
Below is a bunch of other stuff I have for sale. Some of the items I am flexible on (wasn’t sure on pricing), some of the items I am not. Shoot me REALISTIC offers, and i will see if it falls in line with what it’s worth. Items without pictures are still in the car. Shipping and Paypal fees are at buyers’ expense.
LS6 Intake with Potz Ported throttle body - $450.00 -ONLY FOR SALE AFTER ENGINE SELLS!!! (I won’t respond to requests until engine is gone)
LS1 Fuel rails and injectors (may be 36#, I need to check) - $50.00 PENDING
LS1 F-body Waterpump (34,000 miles) (does not include bolts or thermostat) - $100.00
Hooker LS1 F-body headers (EGR provisions cut off and welded shut, and the headers were coated with high-temp grille paint) - $125.00
Mufflex 4" Single outlet exhaust system with Spintech muffler and Y-pipe (also was coated with high-temp black grille paint) - $425.00
SLP air lid, air lid base with clean K&N filter and stainless hardware (does not include IAT sensor) - $200.00
85mm Delphi MAF with pigtail - $85.00
F-body AC system (34,000 miles) (condenser, compressor/bracket, dryer, belt, hoses) - $175.00
(2) T56 crossmembers - $50.00 each
Ebony Leather Camaro seats (power driver side) (driver side has side bolster has a small hole warn, otherwise they are clean) - $300.00
304SS 2.5" mandrel bends, 3’ straight, 3.5" to T6 transition (does not include merge) - $100.00
304SS T6 merge (incomplete, needs finish weld and a surfacing, flange is tapped 1/2" 304SS, has mounting tabs) - $100.00
Mild steel 2.5" 180* bend and 3/8" divided MS T6 flange - $25.00
ABS block for non-traction control car - $50.00
Traction control module - $40.00
(2) E-brake handles - $40.00 each
(2) E-brake cables sets - $35.00 each
Stock LS1 sway bars - $25.00 each
Stock LS1 motor mounts with rubber - $25.00
SLP SS grille - $125.00
Rear calipers from 2001 Camaro with 35,000 miles (includes newish pads and hoses) - $85.00
8" TH400 LS1 torque converter (was $900.00 from Comp Trans, need to find specs, only a few hundred easy miles) - $400.00
4" Steel HD driveshaft for long shaft TH400 to 9-inch rear in an F-body - $100.00
LS1 F-body k-member with break lines and motor mounts - $85.00
2000 F-body Decarbon shocks and stock springs (under 30,000 miles) - $85.00
Edelbrock 1411 Performer Series 750CFM Carburator (Very light use, it looks like new) - $200.00[img][http://i3.photobucket.com/albums/y78/TurboLS1ss/IMG_3703.jpg/img]
Nitrous Outlet nitrous pressure gauge - $25.00
2 Cruise control modules (1 w/ TCS, 1 w/o TCS) - $50.00 each
26 spline Spicer slip yoke - $25.00
LS1 Camaro front bumper support - $40.00
SLP Fan switch - $40
Air bag (for fun) - $30
7 MSD & 1 Taylor plug wires - $25.00
Jaz Overflow tank (plugged the breather pinhole, can be drilled back out) - $15.00
Jaz Oil Breather - $30.00
