MAF Sensor plus plug
Hello all… I need a MAF for my SR20… the wire harness has the plug on it for the SR maf…
So if I could get a SR maf then that would be awesome… if not a SOHC will do, I just need the plug for it to wire onto the harness as well then?
Also… a Maf from the 300zx or Q45 can be used correct ? is there any difference in using one over the other ? or an advantage?
I’d like to pick one up as close to Kitchener as possible please…
Thanks
Jeff
Got one… so the search is over…
