im not sure if im going to try to rebuild my b16 tranny or not. It need 4th gear and 3-4 sycros and i may go ahead and do 1-2 sycros while im there…
i need to know f there are any one on here or anyone know a shop that is good with manual trannys?
i can get parts at cost from the dealer…so i will only need labor
i helped jay redo mine after i payed somebody to to it and they put the main bearing in upsidedown causing all of the little balls to destroy my tranny to on the dyno… call hybrid they are intimadating but once you get it apart its not that bad
yeah it really doesnt look bad but i havent ever had to rebuild a manual one before…ive done a couple autos but not manual…i may just give it a try
It isn’t bad at all actually. As long as you keep everything in order it is easy.
