I am pleased to offer these high quality Magnetic Oil Pan and Transmission Drain Plugs. If you have recently done an engine rebuild or transmission rebuild these plugs are a MUST in my opinion to protect your freshly machined cylinders or new Close ratio gears from metal particles.
More Info:
-Increase your engine/transmission lifespan by removing metal shavings from your oil with this super strong magnetic drain plug
-This will prevent premature damage and will keep metal shavings from circulating throughout your engine/transmission
-Our plugs replaces your stock OEM drain plug with hassle free installation
-Although your oil filter does a good job of cleaning your oil it will not stop the metal particles/flakes from circulating in your system
-Our Magnetic Drain Plugs come with a crush proof aluminium gasket to stop leaks and utilises a neo-dymium magnet which will not rust
-This product provides you with cheap insurance and provides a way of indicating a problem that you may not be aware of before it becomes serious
-The image shows our magnetic drain plug lifting an old Cam Gear, a rear camber arm (Weighing over 1.3kg! You would be hard pushed to find a competing plug able to lift even half that weight!) and 2 plugs attracted to each other through a solid wood shelf
-Beware of cheap plugs on the market with a weak magnet, these plugs will provide a false indication as the particles will be washed away when you drain your oil or when you start your car
-Made out of high quality aluminum
Fitments Available For:
- Honda/Acura Oil Pan Fitment
- Honda/Acura Manual Transmission Fitment
- Lexus Oil Pan Fitment
- Mazda Oil Pan Fitment
- Mitsubishi Oil Pan Fitment
- Nissan Oil Pan Fitment
- Subaru Oil Pan Fitment
- Toyota Oil Pan Fitment
- Ford Oil Pan Fitment
- GM Oil Pan Fitment
- Vauxhall Oil Pan Fitment
- Opel Oil Pan Fitment
ALL FITMENTS IN STOCK
These magnetic drain plug sets sell for $30+US from other companies but we feel we can do better.Well it’s october so pricing is now $15 each or if you purchase more than 1 it is $10 for each additional plug (first plug is $15 and everyone after that is $10). For anyone who wont be able to arrange pickup with me shipping is approx $2.50 with packaging costs and everything included, add $0.50 for each plug after that.
Contact Info:
Chris Richardson
Touge Tuning
Email: Sales@TougeTuning.com
MSN: TougeTuning@hotmail.com
Metal from close ratio gearset break-in, magnetic drain plugs are incuded with all FD and close ratio gearsets.
