I need the following, I’m located in Waterloo so if you’re far away I’m only interested if you have multiple things otherwise it isn’t worth the drive. Everything is for an S14
-KA rad
-Power steering rack NO LEAKY ONES!
-Power antenna with wire
-Rear speaker covers or whole panel
-Spare tire 5 bolt
-Trunk rear panel (the one behind tail lights)
-Trunk carpet and whatever you call the panel that sits above the spare tire
-Wingless trunk springs (I’m assuming they’re not as strong as the wing trunk ones)
-Wingless trunk (Only interested if it’s OEM black)
-Trim ring around the key
-Radio trim (not broken… if one still exists)
-New solid subframe bushings if you happen to have them for less than $100, otherwise I’ll just get them from Bing
