Hey guys…
I have a 91 240sx and i bought a momo steering wheel and momo hub made for a 240sx. When i install the hub and the steering wheel the steering wheel is very hard to turn and i cannot figure out why its soo tight to turn but with the stock steering wheel it turns easy.
a smaller diameter wheel will be much harder to turn than a oem wheel, what size is yours?
also ensure that the center nut for the hub isn’t on super tight, use your hands to tighten it and u may want to add lock tight as well, after time, the nut may become loose
I had to trim the plastic of the adapter when I installed mine.
It was rubbing on the steering column plastic cover.
its a 320mm wheel…
thanks for the help guys
