hey i got a msd coil blaster 2 to be exzact! with a ballist and mount !!! does any one know hoe to use this one a 240?? there is alot of stuff on the stock coil that i don’t know what it is !!! any help would be awesome
thanx in advance
I havent had a KA or worked on one in like 2 years now but I think there are only 2 things on the Stock Coil (wire going to the distrib & a 1 plug)
Remove the Plug (just let it hang there or what not) then install the MSD Coil near the same location as the Stock Unit (so that the wire will still reach from the Coil to the Distrib)
Then you gotta run a Power & Ground wire to the MSD Coil so that it has power…
Dont hold me too it 100%. I may be wrong, but that is how you hook up an Accel Ingition Coil and their pretty much the same thing as the MSD unit. But Im sure someone else can confirm whether Im right or not…
Have you checked www.msdignition.com for a Install Manual ? (if they have them on their site that is)
