hey guys
im parting out my drift car
-advan avs model 6 17 x 9 + 20 5 x 114.3 with Ventus HR2 fronts 215/40/17 still good tread about 45% little worn on the edges from a few understeers but they are good still Continental – ContiTouringContact 225/45/17 rears low tread drivable $1200 ill throw in another pair of 225/45/17 for the rear
-q45 front calipers mint pads and mint rotors they bolt up to stock 240sx brake lines too!!! $200
-jdm s13 rear calipers work amazing and ebrake locked up like a champion $140
-s13 lca’s with new s14 balljoints pressed in $100
-5 lug swap $450
-black dash $60
-black driver mirror $20
-black drivers side fender $40
-hicas steering rack $60
-hicas rear sway bar $60
-clutch master cyl hardline and slave combo purchased new 5,000 km old $120
-tail lights $10 each
-abs manual driveshaft $50
-Pioneer front door speakers 100w 2 way model # ts-a1387 $50
-origin stylish side skirts identical to the ones on my car brand new $350
-dart izumi with ecv(apexi exhaust control valve) $800
-tein superdrifts 10/8 spring rates 8,000km’s on them since new $1250
-greddy VSPL fmic with piping $650
-180sx center rear taillight garnish $60
-momo steering wheel with boss hub $150
-black under taillight garnish $40
-s13 jdm engine mounts $60
-coolant overflow reservoir $30
-s14 4 piston front brake setup calipers rotors pads $360
-manual clutch pedal $40
-manual brake pedal $40
-1991 + 240sx cluster $50
-sohc mafs air filter adapter with k&N filter $60
-sohc mafs $50
more stuff ill post later
647 888 6919
Avery
