Brand new, never used. Pretty cool little gadget.
The WOT Box adds two major features to any car. They are No-lift shifting and 2-step launch control. Both of these features are completely user-programmable using the WOT Box Graphical User Interface.
[B][B]The [B]No-Lift Shift feature makes no-lift shifting easy by cutting your engine’s ignition for a very short period while you no-lift shift. No-lift shifting is keeping the gas down through the shifft. The ignition cut allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. Keeping your foot down through the shift also allows you to hold boost through the shift, thereby significantly improving your E.T.
[/B][/B]
The major benefits are:
- Lower ETs
- Reduced chance of missing a gear
- More consistent, effortless shifts
- Reduced wear on the transmission
- Reduced chance of major transmission damage
- [B][B]
[LIST]- [B][B]
The 2-Step Launch Control modulates the ignition by cutting power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. You can use this feature for a more consistent and more powerful launch in boost!
[/B][/B][/B][/B]
[/LIST]
[/B]
SOLD[/B][/B]
[/B]
