you guys are alot more experiencedwith this than i am!!! my car has got 315842kms on the engine!!! i thinks it had a rebuild or engien swap or something cuz this engine is strong!!! but i dunno the car is being painted right now and everything is being done but do u guys think i should save up and just sr20 it or do you think i should rock the ka? whats the better engine!! and what will i be more satified with in the end? do u think i should just run it till theres a problem or think ahead??
i need some help!! some suggestions!
lemme know
It might be a rebuild or the stock engine might have been taken care of well, you never know!!! Whether you swap in an SR, turbo your KA or keep it stock depends on what you want to do with your car!!! The better engine is defined by your preference!! If you want a street driven car, you’re best off getting some power first!!! If you want to race, and learn to be a truly fast driver, stay with a lower powered vehicle!!
These are my suggestions!!
if it runs strong, use it, teh SR can be expensive,
for the SR route, just buy all the little stuff that will be needed, ie: fuel pump, FMIC, rad…
But if the chassis is strong and the engine too, then you may be better off doing brakes/suspension/wheels…
strong engine in a sloppy car is a poor combination…
i see a lock in this threads future.
seems like another KA vs SR swap thread.
And of course what is involved and costs, and yadda yadda.
