did any bags at all blow?  or did the seatbelts lock?  dont forget that the female part of the front seatbelts has an air bag actuator on them too if you cahnged out belts, dont forget about them.
let me break down the air bag system for you–
sensors “a” and “k” are connected to the driver’s and passenger bag, along w/ the driver’s steering wheel clock spring.
“f” is the side impact sensor.  it is linked per seat and tied into the srs system.  only one side will go off, unless your hit from 2 sides at once.
now, your snap-on scanner should be able to read the srs codes.  other than using a pgm or hds, i cant think of a way to read them aside from a quality tool truck obd reader.
i know you can clear the memory though w/o using a scanner.  try to clear the memory and see if it comes back on.
to clear it, do this—
1)Make sure the ignition switch is OFF.
2)Connect the SCS service connector to the MES connector (2P) . They tell you not to jumper it, but i have done so w/o problem.
3)Turn the ignition switch ON (II).
4)The SRS indicator will come on for about 6 seconds and then go off. Remove the SCS service connector from the MES connector (2P) within 4 seconds after the indicator goes off.
5)The SRS indicator will come on again. Reconnect the SCS service connector to the MES connector (2P) within 4 seconds after the indicator comes on.
6)When the SRS indicator goes off, remove the SCS service connector from the MES connector (2P) within 4 seconds .
7)The SRS indicator will blink two times indicating that the memory has been erased.
8)Turn the ignition switch OFF, and wait for 10 seconds
9)Turn the ignition switch ON (II) again. The SRS is OK if the SRS indicator comes on for 6 seconds and then goes off.
