need idle air control valve civic
need an obd1 idle air control valve for my civic. mine is bad and cant run my tuned ecu till i get one that works
Take it apart, spray wd40 in it and free it up. When the go “bad” its just becuse they get stuck and dont work anymore
i wish thats all i had to do, te one the kid gave me doesnt even have the coolant hoses on the bottom of it!!
I got a couple obd1 intakes floating around i should have one.
Dseries?? I will look n get back to u
yea d series
I deff have one then.
where are you located ill come buy the thing. apparently there not that easy to find as i thought
honda dealer?
pretty sure they are like 170 from honda…
Im PRETTY SURE that D and B series IACV’s are the same…
negative
b series bolt holes are closer together so only one bolt can go thru
