Looking to see if someone has a good idle air control valve. Just checking here before i go out and buy one. motors a b16 if that matters.thanks:)
also anyone know where to get one at a decent price??
412 728 2558
rob
412 728 2558
rob
i got a spare or 2
Did you clean yours by chance Rob? I’d do that first before you replace it
yea i tried cleaning it twice with no luck.
give me a call,thanks
412-728-2558
Rob
is it the larger bolt bole one or the smaller
rob u never picked this 1 up
yea i def want to pick it up. Maybe we can meet up today?
I have one off a JDM b18b, looks new, $35 if you want it.
ttt
anyone.i was told a iacv from a delsol b16 would fit and i found out the hard way,its too short.
I might have the right one here… i can take pics, measure, whatever you need.
Is yours definitly bad? you have a cel on? How you check it is to take 12v leads and jump the 2 connections on the iacv. it should jump one way. swap the + and - and it should jump the other direction. Doing this also helps to knock some additional crud out of them.
Hope that helps… lemme know.
