well i got the crx running but its throwing a code saying the air idle control valve, i put a blox intake manifold on it, btw its a b16a1 in a crx,and i took the old one off my old stock intake and it still didnt work, check the wires made sure everything is right , so anyone have one willing to sell, or any ideas on how to fix mine
take it apart and clean the entire thing…then try again.
You can also check it on the car. If your car is idling, unplug the IACV and the idle should drop or die if the IACV is functioning. If you test it that way and nothing happens, the valve is bad. If it does work, and still throwing a code…try taking off the intake tube while it’s running and put your finger over the upper and lower bypass port on the inside of the throttle body. Plug each one (1 at a time) and see if the idle stumbles or dies.
thanks alot for the help ill try it later on tonight
