used search, used the downloadable manual but im havin trouble findin it in there… manuals im use to have it in the install part right where you would need to do it…
installed coilovers and new front spindles…
coilover front and rear torqued to ???
steering pinion nut torque ???
lower spindle balljoint torque ???
thanks in advance
              hey man what manual do you have? I have the official Manual from nissan i can send you. its all pdf format and it should be under the suspension section. it helped me torque my door bolts to the right amount I’m sure it will have the suspension. but its for a 91-93 s13 hatch or coupe. PM me if you want it I will Zip it and send it to you.
