needed: fuel pressure regulator
im in need of a new one. mines not working any more.
hopeing some one can help me out?
does any one know if i can run a stock one if i have big injectors?
thanks alot
Austin
with upgraded injector’s u should usually switch to an aftermark fpr…people will tell you the stock one will hold a constant pressure, but there usually totally screwed up already or in bad shape.
The SR one is pretty good stock. I know there are LOTS of people that run a stock regulator with 550CC injectors. I have a spare regulator 35 bucks
If you are in Calgary, pm me. I may have the stock SR FPR at home.
I can sell it to you cheap.
