Brand New in box…Looking to get $90.00…PM me if interested
Polk Audio’s Mobile Monitor Series subwoofers bring out superior performance from lighter materials, so you’ll get the impact you want without the extra weight of a conventional system. Advanced engineering and optimized components reproduce your sound with uncompromising accuracy, for low end that is rich and clear.
The MM1040 10" 4-ohm subwoofer handles up to 350 watts RMS. A copper voice coil and neodymium magnet motor drives the polymer cone with exceptional efficiency. The carbon composite basket features a “wagon wheel” design that resists flexing during heavy excursion, so your sub hits solidly without distorting.
This sub is certified for marine use, and Polk includes corrosion-resistant stainless steel mounting hardware.
Details:
10" 4-ohm subwoofer
polymer cone
butyl rubber surround
optional matching grille complements the basket design
power range: 100-350 watts RMS
peak power handling: 700 watts
frequency response: 24-200 Hz
sensitivity: 91 dB
top-mount depth: 4-1/2"
sealed box volume: 0.66 cubic feet
