Sony 12" subwoofer
1200w
XPLOD XS-L121P5
Features:
12" Polypropylene Cone
1200W max input power (350W RMS)
Unique cone design offers superior rigidity
Gold-plated Binding Posts
Small sealed/ported enclosure optimized
4 ohm Voice Coil
Detailed Features:
Gold-plated binding posts – A solid, secure, simple and capable method of transferring serious current to speakers with protection against corrosion for lower resistance.
Polypropylene cone – A plastic based material used primarily for speaker cones due to its resistance against harsh environmental conditions, rigidity, and damping.
4-layer edge-wound voice coil – Start with an aluminum former and wind four layers of copper wire that’s flat, rather than round. This allows the wire to pack together in a smaller space than would otherwise be needed. More copper means better current handling, so the woofer can take more power! The aluminum former retains its shape and resists very high temperatures without burning or melting.
Dual “Triple-layer” damper – Three layers of high strength damper material makes up each of the two spiders, ensuring virtually perfect linear travel of the voice coil. The lead wires are embedded in the top spider, preventing entanglement and extending the voice coil’s throw.
Pentagonal Cone – Improves cone rigidity for lower distortion, and reduction of standing waves on the cone itself, for cleaner sound and better transient response.
Specifications:
Sensitivity – 89 dB/W/m
Frequency Response – 18 - 2,000 Hz
Mounting Dimensions –
Diameter – 277 mm (11")
Depth – 161 mm (6-3/8")
Weight – Approx. 5.7 kg (12 lb 10 oz) per speaker
mounted in a CRUNCH USA 12" bandpass box with the plexi replaced with MDF to stiffen the bass…
SYSTEM POUNDS HARD!!! alot of people have heard it in my delsol and can say it does…
$100 or best offer.
