Nissan B13 GA1.6 litre engine performance parts
I will consider Best Offers.
contact via PM or email: largerpictures at gmail dot com
Thank you.
Frank
If you have a B13 Nissan (NX or Sentra) these parts will be bolt on:
Hotshot Header $150
AEM bypass filter $25
Fidanza Aluminum Flywheel $175
UR Aluminum Crank Pulley $100
Bully Stage 3, 3 Puck Clutch $225
OEM clutch (less than 10 K on it) $150
Outlaw Engineering GA16 Intake Spacer Kit $ 75
Outlaw Engineering SR20 TB spacer only $ 20
SR20 portmatched throttle body $100
Calumsult Prototype GA ECU $225
OEM ECU $ 50
JWT S1 Cams $275
OEM Cams $ 75
Phantom Grip LSD with Green/Gold springs $175
Mishimoto Aluminum Rad $250
(banged up from shipping – no leaks. Used for two weeks)
