Nissan Hardbody 5 speed trans
4 cyl, 2wd. my autotragic went. im not putting another shitty auto in it because i want to blow the fucker up with spray, since i have a second motor.
anyway. hardbody trans. if you happen to be parting one i’ll take the clutch pedal assembly, shifter/boot, clutch master and slave.
PM with price and location
don’t lose your shit if i don’t respond fast, i get on here maybe once a week.
Close ratio from a zx or regular from a 280z? I can get both.
preferably a hardbody specific trans. the overall case is shorter then any of the car transmissions and i’d have to fuck around getting a custom driveshaft built.
buuuuut.
price?
usually 75-200 each I can locate a clutch and pp too. what motor do you have in it, if its based off the L engine everything will bolt up
KA24E. i know a z31, z32 trans will fit with a different bellhousing, the s13 KAs are bolt up, and the SR fits, again with a bellhousing swap.
I can find an s13 tranny too, let me make some calls
