Nitrous Express Direct Port Kit-This is a brand new, never installed nitrous kit. This kit was designed for four cylinder applications to run a nitrous line to each runner on the manifold. Comes with everything you need. Asking $300.
this is tempting. any trades considered? something i want but not bad enough to fork out the money.
Can u post pics of what it all comes with??? lines, bottle warmer ect ect…
Hopefully this will help. No bottle warmer, all the hard lines, braided lines, solenoids, switches are there to get up and running. Not looking for any trades at this time, could use the cash to pay off some things.
bottle certification current?
No current registration from DOT after further inspection of the bottle. If need be I will work something out with the buyer to get the bottle recertified.
Edit-Stamped into the metal of the bottle is a DOT-3AL1800, assuming the bottle is pressure tested to 1800psi.
Yes, that is the pressure test. There should be a few other codes on it to let you know when it was manufactured and when it’s cert expires.
