I came across a limited deal on some quality oil catch cans and decided to purchase them to pass on the discounts to my customers. These are made out of 6061 T-6 Billet Aluminum and come with everything needed to install. For anyone running high hp motors or even just high compression these are pretty necessary in relieving crank case pressure and catching/containing blow-by that cause sludge and carbon build-up. These are ideal for turbo applications which tend to have higher crankcase pressure and more blow-by. I have 10 of these in stock and the price is $70 Taxes included. Please PM or Email me if you are interested in purchasing or have questions regarding this or any other product.
Chris Richardson
Email - Sales@TougeTuning.com
MSN - TougeTuning@hotmail.com
Features:
-6061 T-6 Billet Aluminum construction
-Polished finish
-Dual mounting points
-3ft. of High Silicon Clear Fiber Reinforced Tubing
-Mounting Bracket (1)
-9mm fittings (2)
-Drain fitting on bottom (1)
-Worm Gear Clams (4)
-Sight Glass tube (1) with Fittings (2)
-Can rotate top of canister for easy installation
-6" Tall x 3.5" Wide
*15mm Fittings pictured
