Oshawa Engine swap. 2jz-s14
Have pretty much everything done. WIll just need some assistance dropping her in. If you have a hoist will be additional bonus. or a way to help me get off the crank pulley bolt. The crank pulley is off had to put the bolt on to torgue down pressure plate. Send me a txt 416 823 6205. I can compensate if need be
things happenin
Karkas and I have got the engine in, but we are unsure of how to lineup the mounts? Any help? Orientation etc…
my suggestion to enlargen the mounting tower slots was something that was not suppose to be not a necessity at the time…
do you have the motor mount brackets in the right spot? The 2jz block has threads for front sump mounts and rear sump mounts, what kind of mounts are you using?
Front sump came from an aristo, rear sump is in supra
Front sump is the easier one to put in 240
Just make a set of these. Or buy em…
got blitz exhaust for ur setup.
