hey…i know a lot of you guys on here are good with this kind of stuff…I for one, hate physics and it just doesnt click for me…:tdown: :\
can anyone help me with these problems? if so…and i see you out, i’ll buy you a shot, lol. thanks!
1.) The potential difference between the accelerating plates of a TV set is about 25 kV. If the distance between the plates is 1.8 cm, find the magnitude of the uniform electric field in the region between the plates. (the answer should be in N/C)
2.)A point charge of 3.00 10-9 C is located at the origin. How much work is required to bring a positive charge of 3.00 10-9 C from infinity to the location x = 30.0 cm? (answer should be in J)
i could have answered these questions about 10 years ago. but i have systematically erased from my memory everything i learned about physics and calculus by killing my brain cells with lots and lots of beer. :gotme:
r u doing the problems on web assign obviously…i wonder if they’re the same for zeng…just realized there are 2 assignments due today, and instead of being due at 11:59 like i thought they’re due at 5 , guess nows a good time to start lol
yea zeng must have changed the due date for the first assn to today, cuz this is the first one i’ve had to do, i dont know y its due at 5, o well i’m halfway done with the first one
i only have one due
webassign wasnt working all last week and it says there was an assignment due last sunday…ugh.
thanks i solved those problems…:tup:
ive been reading the book but i got so confused and frustrated, i just couldnt focus on one page in the book to see how to do them…
i need a phy tutor…this has nothing to do with my major but yet i have to take 2 semesters of it…
im gonna be a PT…dealing with fixing peoples body parts, not trying to figure out voltage to some capacitor…lol :tdown:
Ooh…one more thing.what about this one?last one i promise.
Two point charges are on the y-axis, one of magnitude 3.0 10-9 C at the origin and a second of magnitude 6.0 10-9 C at the point y = 20 cm. Calculate the potential at y = 60 cm.
Yea, I just read the summaries at the end of the chapters, and go to recitation. The book is very confusing, exp. with their examples that are way to complicated.
I hear you with having nothing to do with your major, it sucks :tdown:
ha organic now thats a different story, test this week and i have no clue about spectroscopy nmr, mass spec, dude i’m fucked and this is the second time around
i had savino last year, he is an awesome guy dont get me wrong, but when i got the tests i had no clue wat to do, he joked around to much and i didnt learn a thing, and this semester i purposly chose the 8am class to get away from richards, but he’s teaching that now to, he’s by far the worst and i’ve had them all between retaking both 201/202, gong, richards, savino
ok now i need some help… 2. [SerCP7 16.P.028.] A small object with a mass of 340 mg carries a charge of 35.0 nC and is suspended by a thread between the vertical plates of a parallel-plate capacitor. The plates are separated by 4.00 cm. If the thread makes an angle of 12.0° with the vertical, what is the potential difference between the plates?
[SerCP7 17.P.012.] Suppose that you wish to fabricate a uniform wire out of 1.10 g of copper. If the wire is to have a resistance R = 0.300 , and if all of the copper is to be used.
(a) What will be the length of the wire?
m
(b) What will be the diameter of the wire?
µm
Edit: Nevermind, figured it out, if anyone needs to know also let me know.
o man bro that was a bitch u have to look up the density of copper online, i was fuckin pissed i sat there for 40 minutes thinking something was missing…then u solve for the volume of copper that u have and volume = length * crossectional area, solve for one variable and substitute it to the equation R=pl/A
EDIT: I saw ur edit lmao, o well too late someone else mite need the explanation
