Wherever youre at right now, home or work or whatever. Post your speeds.
Use this test for consistancy.
http://twcbusinessalbany.com/myspeed/
Download 10.2mbps
Upload 12.3mbps, currently.
2.34 mbps down
718 kbps up
at work, i’ll check when i get home
Download 25.7mb/s
Upload 55.4mb/s
I cheated, I’m at school
Download 35.0 kbps
Upload 24.7 kbps
:ninja
Download is 8.3Mpbs
upload is 983kbps
download = 707 kbps
upload = 106 kbps
fuck clifton parks road runner
19.42 Mbps down
15.01 Mbps Up
as of 2:26pm March 31, 2008
how old is ur modem, Travis? Mine pulls good speeds most of the time, unless its peak time and the whole town is downloading pr0n at hmoe. I’ll speed test it when its off peak time and post it here
dl=4.84mbps
upload=300kbps
not sure if thats good or not
Speed test statistics
Download speed: 5466792 bps
Upload speed: 978368 bps
Quality of service: 84 %
Download test type: HTTP
Upload test type: HTTP
Maximum download pause: 31 ms
Average download pause: 12 ms
Minimum round trip time to server: 29 ms
Average round trip time to server: 32 ms
Server test
What do you have
dsl?
RR?
T1/T2/T3?
Down = 3.24 Mbps
Up = 966 kbps
the modem isnt the issue unless he’s using the Motorola surfboard, which if memory serves me correct do not even work anymore on the TW network since the upgrade last summer.
its either one of two things.
1.) way too many RR users in your area, and some are pulling down massive files
2.) the lines to your house need to be checked out by a tech. there may be interference on the line.
i just went through #2 last year, and they ended up re-wiring the house. that also cleared up all the scrambling of the digital cable channels, etc.
ill have to see if i still have the links bookmarked at home when i get home later tonight. if i do ill send them to you, and then have you send or post up a screenshot of the graph that will be displayed.
edit:
and here @ work, my speeds are…
Down: 149Mbps
Up: 114Mbps
the download is 8.93 mbps
the upload is 988kpbs
is this good? is my computer is good working order?
alittle slow on the upload. download is right about where it should be. upload should be around 1.5 - 2 mbps if your getting a perfect connection. some areas will be higher though, and some lower. depends on line conditions, etc.
dont use that speed test… it tests way lower than the time warner one
this is some RCA box modem… fucking garbage… had several techs show up and try messing with lines… never rewired the entire house though… as sad as it is the numbers used to be around 505kbps downloand and 75kbps upload
I win :number1
kbps is smaller than mbps
Killobytes per second - 1000 = 1 MB
Megabytes per second - 1000 = 1GB
