sold already
Nice front bumper hope it ain’t sold yet.
My rollcage 101.
The cage was built by a shop that is now closed down in spring of 2008. It is made of seamless DOM piping, initial idea was to have 1.500 x 0.095 but I believe we went one step up in either thickness or diameter as I had plans of racing it in another series that required greater specifications. It was built to meet DMCC which was essential Formula Drift rule book since FD judge Andy Yen runs DMCC ever since 2008.
What I was looking for in a cage was:
- Side hoops (A-pillar hoops) as close to the A pillar as possible to reduce visibility interference normally created by rollcages.
- Main hoop as close to the B pillars and roof as possible to minimize crumple if a rollover was to occur.
- Roof bar (diagonal going over the drive/passenger area)
- Windshield diagonals, Sidehoop diagonals.
- 1/4inch contact plates on at least two surfaces at each contact plate as well as wrap around 1/4inch plate on strut towers
- Each mounting plate shall not be greater than 100 square inches and shall be no greater than twelve (12) inches or less than two (2) inches on a side
- Front hoop leg welded to contact plates at two axis
- Inside-dash bar
- Steering column is bolted to a support plate on the dash bar
- 1/4inch plate welded loopholes for the lower harness straps
- transmission tunnel bar welded to the transmission tunnel (see fire extinguisher pic)
- floor bars connecting main hoop and front hoop at the bottom
- 1/4 triangulation plates at the X configured door bars
Here you can see the floor bars and x bars.
Windshield diagonal
Main hoop diagonal
Main hoop to B-pillar proximity
Main hoop leg and plate
Side hoop leg and plate, notice how its welded on the side too.
Strut tower plate
Transmission tunnel bar welded to trans tunnel.
In-dash bar
Harness loopholes
Chassis, it’s all greasy everywhere from the motor destruction.
Hydro ebrake lines ready to go.
e
Chassis has: front cross member, tc rod brackets, rear subframe with LCA’s and rear knuckles, gas tank with a walbro 255 in it, wiring harness, sr cluster, dash, wiring harness will work with JDM s13 sr20det engine harness, you don’t need to rewire jdm engine harness to canadian chassis, plug and play (ecu on the left), pedals, throttle cable, brake booster, all fuseboxes, rear rebar with towhook, custom 1 piece chromoly front strut tower bar.
If you want, I will include stock front and rear swaybars, a pair of axles, full stock multilink, 4lug, and a pair of axles, driveshaft with it, this is the stuff I took off originally when I was building the car.
The windshield is not cracked, and there is no hatch.
To race this chassis you will need: Motor/tranny/engine wiring harness, coilovers, seat, steering rack. You can run the stock multilink/diff/tie rods I can provide or you can get aftermarket your choice. The rear brake lines are good until the T where they split to left and right wheels, you will need to change the two short pieces that go to driver/passenger rear wheels as I cut the ends off them.
I would grab a fresh chassis harness from someone parting out, but current one still works. Chassis was smashed in the front a while ago, but fixed and I still ripped it for many track days after that, it aligns with no problems.
I also have an exhaust for sale, HKS vband with springloaded muffler and 3.5 inch inner diameter, banged up but sick as fuck, 400$
and this stuff
Z32 MAF with pigtail
S14 sr stock rad (thicker than oem)
S14 tc rods with energy bushings
S14 oem front swaybar
S14 stock front seats
S13 doors
coils and wing i want if in good shape.pm me if u still have…plus will need other parts putting together a sohc in my garage am interested in anything that will make it go faster and look + perform better let me know if u can help thanks alot pm plz…
Just because there were many inquires on both, I will separate the wing from the hatch if two buyers: one for the wing; one for the hatch - approach me with the money for both parts.
selling second wideband- 200$
I just remembered 1.500 x 0.120 was the spec.
front 5 lug conversion … cash in hand ready to send
already sold
and aem uego wideband SOLD
still got vlsd>?sideskirts and overfenders?
still got vlsd and side skirts
still got hatch an wing?
hey man i would like to take those Teardrops with the all seasons off your hand, do you still got them?
yes
sold
STUFF ADDED:
S13 NISMO POWERBRACE - 180$
S13/S14 JDM aftermarket adjustable TC rods - 200$
Momo wheel and hub - 180$
omori boost gauge - 60$
jdm aftermarket rad (looks like stock but super super thick - so cops can’t tell, i think its yashio factory) - 200$
s13 complete smic kit - 140$
s14 complete smic kit - 140$
s13 sr rad shroud - 20$ each
180sx brakes (pads/rotors/calipers/lines) - 150$
180sx front sway - 50$
hicas rear sway - 60$
t25 jdm mint turbo - 140$
s13 doors white manual - 80$ both
s13 clip with jdm brake/clutch masters/pedals/dash/steering column/cross member - 80$
s13 sr20det redtop motorset complete with wiring harness/tranny/ecu - 2000$
motor is still in the front clip, 175psi compressoin test, oil is clean, no sludge anywhere on the motor, i can start the front clip for you.
unknown JDM 4lug bolt on spacers 10mm - 70$
s13 sr20det redtop untouched wiring harness and #62 ecu 300$
im willing to drop the price on alot of items dont hesitate to message me with offers
complete intake manifold with injectors and fuel rails and idler valve and everything fresh off a running front clip - 200$
exhaust manifold with t25 and all the lines fresh off the same motor - 200$
complete silvia aircon system , had gas in it still - 50$
mint rhd steering rack - 50$
mint jdm cross members (fits both lhd/rhd) - 50$
rhd dash - 40$
please buy some sr trannys i just got another one I have four!!!11
i i had a wallet full of money right now id rape your collection lol lots of useful stuff for my hatch… like the hatch+lexan (no need for wing i have my own) hmm… would u seperate
theres plenty of people who asked about the wing, i already said whoever wants the wing and looking for someone to buy the hatch and vice versa should just post here
