will or is there any way that a rad from a turbo rx7 will fit on a 240 with an sr20det?
Thanks
Sean
Anything can fit on anything, it’s usally a matter of how easy or how much to make it fit.
As far as an RX-7, if it’s an FC, yes it should fit but most likely you’ll have to change rad hoses. As for an FD, not sure as I’ve never seen how FD rad mounts.
If worse come’s to worse, just make some brackets so it’ll bolt to your rad support. Do a little measuing first of it and of your car and go from there.
Good luck.
Easy 8)
If its a fc and its the same as the na ones and your wanting to sell it for money towards a koyo rad let me konw.
