6 OEM RB20DET injectors, no problems they’re all in good condition and the plastic is not damaged: $OLD
RB20DET oem maf with hks cone adapter $50
RB20DET oem ecu $100
RB20DET oem camshafts I have two complete sets available, both are in great condition $50 each pair
RB20DET oem pistons set of 6 never saw high boost only used stock turbo $100
RB20DET oem conrods set of 6 never saw high boost only used stock turbo $100
RB20DET headbolts complete set $30
KA24DE 5 speed ecu from 93 hatch $40
2000 Altima electric rad fans(you can use it on your 240 with MINIMAL mods) $40
KA24DE 5 speed flywheel good shape not rusty $OLD
KA24DE OEM replacement clutch and pressure plate approx 15,000 km on it still has lots of life. $50
KA24DE/RB20DET ACT SS heavy duty “street” clutch no more then 5000km on it good for about 300-350 tq $250
S13 KA-T 3" down pipe stainless steel for t3/t4 turbo setup. im pretty sure if you re-clock the flange it will work on an rb/sr swap I attempted to use it with my rb20det looked like it would fit if the flange was in the right direction. $100
S13 ghetto catback with the flange cut off on the front no resonator and dented muffler tip, 3" ss bee*r muffler $80
please PM for contact information
