Rb20 w/Ka transmission starter problem.
I’ve got an rb with a Ka tranny bolted up (cut driveshaft and whatnot), its all in there but the problem is the starter isn’t working so I tried using a ka starter but also no luck. Anybody have any advice here?
You could buy my rb25 tranny
I never heard of using a KA tranny before on a rb
Me neither… I’ve heard that it DOESN’T work though… kinda ghetto but i made it fit. Now i want it to work!
dose the starter crank over?
---------- Post added at 08:37 AM ---------- Previous post was at 08:30 AM ----------
try to disconnect starter from the block and put it in a vice attach a battery to it and test to make sure it works if not then get a new one.
both starters crank and make noises so the problems gotta be which one to use and if i was even putting it in straight
Ka tranny fits just fine. Just longer about 2 inches. I even used the ka bellhousing. It bolts up good. Use the rb20 starter. Thats what it needs.
exactly what ali said. theyre the same guts essentially just different bell housing.
You have experience with this chris?
never done it but iirc KA, CA, RB20 and SR trans are all the same except maybe small gear ratio changes and bell housing.
See thats what i always thought but almost everyone i talk to says they arent
it does not bolt up fine u told me urself lol. 4 bolts are missing across the top! lol. u never got back to me about the bench test on the starter? im busy this weekend but if u dont figure it out maybe ill fly up there after work next week on my bike if its not fucking raining and see what we can do about this.
PS whered u get ur driveshaft done? can they make me a one piece driveshaft if i give them my old driveshaft?
Haven’t gotten around to it lol. It was at Cardanic Drive-Line & Machine Shop at 175 Toryork Dr, Toronto, ON M9L 2Y7, you’ll have to give em a call and fin out, they’re pretty cool guys.
