Is the front end suspension setup for an s13 similar to an s14???
please let me know if the same springs/shocks from an s13 can be used on an s14…thanks…
I’m pretty sure that they are the same. The S13 and S14 front suspension should be interchangeable.
i am not completely sure, but i remember reading about it and that they are not the same… someone?
but think about it, why would u specify that u’re ordering shocks for an s13 or an s14? that means that in fact they do not fit
check srswap.com for instance, go into coilover set ups, u have to choose whether u want s13 or s14… there u go
There not the same.
They share some common parts but other than that there different.
By front suspension, I meant the shocks/springs. Thery’re the same, aren’t they?
Well struts and springs are components of a suspension system.
You got to be more specific.
No those as far as I understand are not interchangeable.
Thanks for your help…no one seems to know for sure…
many people say for sure fronts and the same and rears are different… i dont know what to believe so im just gonna try it out and see whats up with it…
thanks…if any one finds out for sure please let me know…
peace…
