im well aware that i may be in need of a new motor come spring cause apparently japan doesnt use a 50/50 mix of coolant. in the event my block is cracked and i need to replace it im probably going to have to source one out. anyways, i plan on removing the engine and transmission at a whole cause i need to perform some transmission work on it anyways. does anyone know where to hook the chains onto to lift the motor out?
…your jap motor is the same as a usdm motor…thats not why your block cracked… :shock:
AHAHAHAHAHAHAHAHAHAHA AWESOME POST!!!
:lol:
toss the chain around the fuel rail
just one is good enough
