Some random stuff I have around.
Black JDM RX-7 S6 (FD) hood, no dents or rust, straight, black - $200
Very clean RX-7 S5 (FC) tails, no scratches beyond the normal cleaning swirls and no cracks or chips, clean front and back plus a clean center garnish. -$220
Team Dynamics 17x7.5" 4x100 +35 2x white, 2x athracite
No rubber , but new wheels, mounted for moving car, that’s it. -$500
Planet Audio 600W tube amp, installed, never used, this is a rare item as PA only made a 2-3 years of these, they were awesome but expensive. -$250
2 WRX Td04-12T - ~ 100k on it, solid with normal play, WELL within paremters, this turbo will make 250hp on a 2L with 1bar (14.7psi) being reached by 3200 rpm, max pressure is 19psi. -$150
PIAA x002 driving lights, new, smallest, high output LED lights made. -$100
PIAA X004 with extreme white bulbs, 2.5" DRL’s… used , 1 lens has a crack ( I can get the replacement at cost ). -$75
PM, email, call, whaterver.
