So, this is the big one, and this is just the start. Once again, prices are fairly firm. I will deliver in the Hamilton and surrounding area (burlington, dundas, ancaster, ect) if asking prices are met. I will not ship, I will not meet halfway, lowballers and stupid questions will be ignored. Pm myself or Jon (cabbagerollz) if you have questions…
Stock SR20DET Intake manifold. Various sensors + stock injectors included. $100
Megan Racing equal length exhaust manifold with stock T25 setup. Turbo condition unknown, there is some play in the shaft. Built and held boost good, but hounestly I dont know whether it is still good or not. $150
SR20DET Starter motors. I have two of them, both work great. $30 each
Stock non-hicas, non abs S13 hatch driveshaft. Hanger bearings and u-joints check out. $20
S13 sending unit + Walbro fuel pump. Sending unit is in good working condition, I believe the Walbro pump is 255lph, but do not know for sure as I did not buy it. $60
APEXi Coolant tank. Aluminum, could use a polishing. New from APEXi for $250 american. $100
No-name catch can. $20
Various exterior lights. $make an offer.
HKS Electronic boost controller. Works great, all wiring intact. $150
HKS Turbo Timer. Works great. All wiring intact. $50
Stock S13 cluster. $15
Stock SR20DET MAF. $40
Stock drivers seat. Kinda dirty, repair on left side bolster. $10
Stock SR20DET. Passed compression and leak-down tests, unfortunatly I do not have pictures to prove this. I was planning on doing a complete teardown/rebuild then putting it into something else, but plans fell through. Always ran on quality synthetic oil (usually Red Line). Could be put into a car as-is, but I would reccomend a tear down/inspection/replacement of components as I had planned to do. 146000km. $800
Stock SR20 5speed transimission. Sorry, no pics at the moment. Run with Royal purple gear oil. No grinds, easy to shift. 146000km. $200
Megan Racing Turbo-back exhaust. Includes magnaflow 3" cat and Megan test pipe, silencer, 02 sensor, and some new hardware and gaskets. Stainless steel, polishes up nicely. Some scrapes and dings from normal use. $600
HKS Air Filter assembly. For SR20DET setup. Selling for over $160 american on ebay. $60
Electric fan setup. Fits perfectly with stock rad. Out of '95 Ford Taurus. Pulls well over 2000cfm according to Ford. Includes relay and toggle switch. Beats paying $180 for a Flex-a-lite. $40
Racing Sparco rims. 5-lug, same bolt pattern as the 5 bolt s-14’s. I’ve seen one other set of these wheels in my life, and they were a pain in the ass to find information on. Get compliments everywhere I go. Offset for front/back. Do not have specific measurements at the moment, but will include a picture of fitment on my S-13 using a pair of 10mm spacers up front. Some curb rash was on rims when they were received with front clip, all rims run straight and true. Tires will be taken off before being sold, they are garbage anyways.
$600 for set w/spacers for front.
Check in for updates…
