email: corriveau110@hotmail.com
hey guys Im selling my whole setup that I have on my car Im getting out of the ka-t scene for now I have moved into an apparment and would like some spare money to play with so I decided to sell my whole setup, I will try to name everything correctly its been a while and alot to remember.
Fully built KA24DE 2,500$
Block is bored .020 over then honed and hot tanked
Crank was hot tanked then polished
Block, Head and front timing cover were decked / shaved
Cylinder head was ported and polished
Lapped the valves and valve seals
- supertech coated pistons 8.6:1
- eagle H-beams 900whp capable
- ARP everything, crank bolts, head studs, rod bolts
- Clevite Maint and Rod bearings Gapped on the looser end of factory specs. motor runs on thick 15w50 mobile 1 changed everything 1000km’s (daily driven)
-Cometic head gasket and full engine gasket kit - new timing cover / oil pump
- new oil pan with welded bung
- Brian crower stage 3 272 cams
- Brian crower dual valve sprins
- stock valves that were lapped
- Polished valve cover
Engine ran great never let me down, doesnt burn oil or coolant, never over heated. Ran 11.7 ish AFR ratio’s at 16lbs of boost. timing kept conservative. I built it to handle over 600whp but unfortunetly never got up to that. The most I made was 370whp at 16psi on the t3/t043 .60trim (turbo is sold)
Custom T3 top mount manifold with 38mm W/G flange and custom 2.5" downpipe, bolts up to T3 4bolt housing 550$
Intercooler piping and FMIC (2.5" on hot side 3" on cold side, ALSO includes Z32 maf (BLOW THROUGH) 400$
Tial 38mm wastegate 100$
ebay bov (SSQV) works perfectly had no issues 50$
custom intake manifold plenum (uses stock intake runners with volocity stacks welded at the ends(inside plenum). includes stock Throttle body and new TPS sensor 400$
Ebay 3" catback N1 style 200$
glow shift boost, egt, and oil press gauges with a pillar pod 250$
Haltech PS 1000 with 5bar map sensor, with full engine loom / wiring harness will need to solder connectors at the ends. 2000$ (paid over 3000$ ALL NEW NEVER USED )
KA24DE Manual Transmission with short shifter 150$
Competion Clutch stage 5+ 4 puck sprung disc, pressure plate and flywheel. 500$ -Lots of life left, used for one summer with one trip at a 1/4 mile
Apexi NEO 150$
AEM FIC 250$
meagan coilovers (street) 700$
S14 seats in good condition 100$
heres some video’s on youtube to show you how the setup performs
rebuild : http://www.youtube.com/watch?v=C7z-72Qhaoc
walk around and couple pulls at 9psi : http://www.youtube.com/watch?v=7cIOjo4CFbQ
action video : http://www.youtube.com/watch?v=q-9m3CZdsvo
http://www.youtube.com/watch?v=Rb5azRORWP0
