email: corriveau110@hotmail.com
hey guys Im selling my whole setup that I have on my car Im getting out of the ka-t scene for now I have moved into an apparment and would like some spare money to play with so I decided to sell my whole setup, I will try to name everything correctly its been a while and alot to remember.
Fully built KA24DE 2,500$
Block is bored .020 over then honed and hot tanked
Crank was hot tanked then polished
Block, Head and front timing cover were decked / shaved
Cylinder head was ported and polished
Lapped the valves and valve seals
- supertech coated pistons 8.6:1
- eagle H-beams 900whp capable
- ARP everything, crank bolts, head studs, rod bolts
- Clevite Main and Rod bearings Gapped on the looser end of factory specs. motor runs on thick 15w50 mobile 1 changed everything 1000km’s (daily driven)
-Cometic head gasket and full engine gasket kit - new timing cover / oil pump and water pump
- new oil pan with welded bung
- Brian crower stage 3 272 cams
- Brian crower dual valve sprins
- stock valves that were lapped
- Polished valve cover
Engine ran great never let me down, doesnt burn oil or coolant, never over heated. Ran 11.7 ish AFR ratio’s at 16lbs of boost. timing kept conservative. I built it to handle over 600whp but unfortunetly never got up to that. The most I made was 370whp at 16psi on the t3/t043 .60trim (turbo is sold)
Custom T3 top mount manifold with 38mm W/G flange 550$
-this thing is solid! thick tubing I dont see it cracking ANYtime soon!!! very well made, and good clearence with the downpipe or brake master cylinder reservoir.
Intercooler piping and FMIC (2.5" on hot side 3" on cold side, ALSO includes Z32 maf (BLOW THROUGH) 400$
Tial 38mm wastegate 100$
ebay bov (SSQV) works perfectly had no issues 50$
custom intake manifold plenum (uses stock intake runners with volocity stacks welded at the ends(inside plenum). includes stock Throttle body and new TPS sensor 400$
Ebay 3" catback N1 style 200$
glow shift boost, egt, and oil press gauges with a pillar pod 250$
Haltech PS 1000 with 5bar map sensor, with full engine loom / wiring harness will need to solder connectors at the ends. 2000$ (paid over 3000$ ALL NEW NEVER USED )
KA24DE Manual Transmission with short shifter 150$
Competion Clutch stage 5+ 4 puck sprung disc, pressure plate and flywheel. 500$ -Lots of life left, used for one summer with one trip at a 1/4 mile
Apexi NEO 150$
AEM FIC 250$
meagan coilovers (street) 700$
S14 seats in good condition 100$
heres some video’s on youtube to show you how the setup performs
rebuild : http://www.youtube.com/watch?v=C7z-72Qhaoc
walk around and couple pulls at 9psi : http://www.youtube.com/watch?v=7cIOjo4CFbQ
action video : http://www.youtube.com/watch?v=q-9m3CZdsvo
http://www.youtube.com/watch?v=Rb5azRORWP0
