Up for sale is a brand new fully race prepped KA24DE. Motor only has approximately 16 hours run time on it.
Asking $4750 obo
Here is a quick run down on the build…
JE pistons 250642 3.504 bore and JE plasma moly rings
Manley rods h beam rods 14006-4
Brian Crower BC2 camshafts
Manley 26160 -16 springs and titanium retainers
Cloyes 9-9180 SA timing chain and gear set
Top Line OPO31L new oil pump and timing cover
Cometic PRO 2014T gaskets
New bronze guides and oversize valves
complete machine work block aline honed/bored and honed plus 20/deck 0 height
crank mag d knifed and balanced
new guides honed to size /comp valve job and head resurfaced
rings file fit and bearings fit to size and assembled complete
Motor comes with…
Computer with Nistune and Wiring harness
Laptop program to tune the engine.
Starter and alternator freshly rebuilt.
ACT clutch
ACT light weight flywheel
Engine is very strong and very well built, dyno sheet attached proves that (This is to the wheels). You will not be disaapointed. Throw a turbo setup on this and make tons of reliable power.
Please contact Claude for more information
705-761-1669
cpoirier@automotivedriving.com
