time for changes so here goes:
fully built ka24de
bore/hone .40 over (90mm)
deck
vat
file fit rings
balance / blueprint
resurface flywheel
valve job
polish crank
reassemble short block
*this came to be right at $1,000.00
Wiseco 9:1 90mm
Eagle Rods
ACL race bearings
Cometic head gasket
ARP main studs
ARP head studs
Kelford 264 camshafts
Supertech dual valve springs
Supertech Ti retainers
Supertech .5mm over nitride exhaust valves
all timing chain and tensioner changed with oem nissan
ran this for 2 summers with no problem,this was only my weekend car so prb no even 7000km,doesn’t burn oil or coolant.oil was change often.never leaned out.made 430whp at 16.5 psi(with 6768 turbo) on pump 91 would make a lot more on ethanol or race fuel
2200$ obo
comp clutch twin disc clutch for ka24de ran for 1 summer less than 3000km,grabs a shit load,
700$
z32 transmission with rb26 bell housing to mate to the ka24de,nissan new 1-4 synchros ran 1 summer,comes with mazworx:z32 to 240sx mount,shifter bracket,short shifter,always ran with redline mt90,this tranny is suppose to handle 800+ hp
600$
mazworx z32 to s14 non abs drive shaft with spicer joints
300$
aem ems 30-1610
95 Nissan 240SX (OBD1)
95-97 Sentra (Except 97 1.6L)
95-97 200SX (Except 97 1.6L)
95-96 Altima (Except 96 CA Models)
94-96 Infiniti G20
comes with 3 bar gm map sensor
700$
comp turbo custom made 67/68 triple ball bearing turbo,billet 67mm compressor wheel,billet non water cooled center section,cast 68mm turbine,anti surge housing,.82 a/r t3 flange 3’’ v band exit,
would need to be repolished
1000$
ka24de ss top mount ramhorn style manifold t3 flange,44mm flange,
200$
ams top feed fuel rail for ka24de with an fittings
100$
4 ls1 coils with pig tail and custom bracket for ka24de
100$
custom catch can/block vent kit for ka24de,valvecover with bungs welded on,ss -10 braded lines,red and blue -10 an fittings,goes from valve cover to baffle catch can then drains back where the stock pcv valve is
150$
if you calculate all the parts its 6050$now i would do a package deal of 5000$ for everything listed plus extra parts i got laying around,this is a almost complete kit that’s good to put down some good numbers
now the reason i don’t know the mileage on these parts is because never had a working speedometer,all the parts are located in Moncton,New Brunswick so buyer has to pay shipping
my number is 1 506 961 3465 text or call for any questions thanks
