Lith
                    November 4, 2009,  7:52pm
                  1
              I have an S13 SR20DET Mine’s tuned ECU for sale. This is what was updated on it:
The speed limiter has been removed.
The injection/ignition timing has been reset.  91+ Octane gas must be used.
The maximum boost pressure has been set as 0.90 kg/cm2 (which is about 12PSI)
The Rev limit has been increased by 200 rpm.
Obviously this ECU is meant to be used with a stock motor and turbo. A friend of mine already tried it on his blacktop and it worked without problems.
I’m located in Toronto and I can ship this at buyers expense. Here are some pics:
I’m asking $200 for this ECU or best offer.
              is this tuned to work with a non recirculating bov by any chance?
                rb180
                    November 6, 2009,  9:15am
                  3
it will work good regardless.
                240sex
                    November 6, 2009,  1:09pm
                  4
              any idea of the increases you gain from this ecu? thanks.
                Lith
                    November 6, 2009,  5:20pm
                  5
              Hey guys,
As far as gains go, I’m not too sure. Easiest way would be to dyno the car with a stock ECU and then with this ECU to see the gains. However, I’m sure you will gain some power with the advanced timing and different fuel maps they put in.
                240sex
                    November 6, 2009,  5:25pm
                  6
              I wish I had $200 kicking around. interested in a 10" sub and amp by any chance? haha
                Lith
                    November 6, 2009,  6:29pm
                  7
              already got a 10" sub and amp
              200 RPM increase on a stock sr20 is bad… suggest investing in Rocker Guards before thinking of offen reving over 6k RPM…
              180sx 3 puiece rear valence or anything, i want this
