- 5-speed transmission
- 5-speed crossmember
- 5-speed driveshaft
- Flywheel
- Clutch and pressure plate
- Release bearing
- Master and slave cylinders
- Hardlines and rubber line from master to slave cyl.
- Clutch pedal
- Boots and brackets for shifter assembly
- Lower wire harness
PLEASE let me know what you guys have!!!
i’ve got a brand new slave cylinder, and im geuessing this is for KA, but if its for an sr i have a brand new release bearing too
oh and not sure if you knew this or not but the brake pedal is different on the auto from the 5 speed so if you dont have one already you might want to add that to your list
