Ok nevermind on the KADE. All I need are all the 5speed swap parts.
5 speed transmission
5 speed Driveshaft
Flywheel (new or resurfaced)
M/T flywheel bolts
Clutch Kit (Clutch, Throwout bearing, Pressure Plate, alignment tool,pilot bushing)
Shifter assembly (plate, lower rubber boot, upper leather boot, finisher plate)
5 speed Crossmember
Clutch Master cylinder
Clutch Slave cylinder
Clutch hardlines
Clutch pedal assembly
5 Speed Brake pedal assembly
Bellhousing bolts for a 5 speed bellhousing
Bolts to hold Pressure Plate to Flywheel
Thanks!
