amazing car trailer - super low and easy to get on and off for super low ground clearance race cars - stop breaking your body panels!
- tandem axles with suspension
- 4 wheel electric brakes recently serviced
- brand new tires, wheel locks
- full size spare good condition
- onboard battery box w/ emergency pull-away brake system (activates 4 wheel brakes if trailer breaks away from the truck)
- LED brake lights and turn signals
- metal ramps slide inside the trailer so you don’t have to carry big hunks of wood with you
- two special made wooden inserts for the metal ramps to make it almost perfect flat if your car has less then 1 inch ground clearance (like mine)
- four hinged tie down rings
- trailer has a class 3 terminal at the front of it for class 3 ready winches
- comes with a class 3 winch with a remote control that inserts into the terminal (stated above) to pull your car onto the trailer after you blow your motor at the track (remote control allows you to sit in the car and steer as you pull yourself on the trailer)
- on board rim and tire rack
- removable rear rebar (protects your precious car from being rear ended by some idiot on the highway while your towing) with proper DOT approved stickers
- comes with a 6000LB class 3 reciever and a 6000LB ball in it, stainless steel polished locks and all keys, ownership, wheel lug key, and four good condition tie down ratchet strap come alongs
This trailer is the most stable open trailer I’ve ever towed my race car with, great breaks, takes fast turns, aerodynamic.
Asking 3000$ for everything.
