Sony DRX-830U External Multi-Format 18x DVD Burner
- DVD+R double layer and DVD-R dual layer burning
- Store up to 8.5 GB of data on one single sided, double layer DVD disc
- Improved writing speeds for all DVD formats
- Record up to 4 hours of video on double/dual layer discs
- Works with 4.7 GB DVD+R/+RW and 8.5 GB double/dual layer discs
Clean up your hard drive and transfer data, music, video and images to DVD with the DRX-830U external multi-format DVD burner.Sony’s DRX-830U DVD burner incorporates 18X max DVD+R burning, delivering a full 4.7GB disc in about 5 minutes using standard 16X DVD+R discs. The DRX-830U supports all available DVD formats including single layer 4.7GB DVD+R/+RW, 8.5 GB Double/Dual Layer DVD+R DL, and DVD-RAM discs. High performance 48X max CD-R burning and 32X max CD-RW burning means you no longer need a separate CD burner. The DRX-830U features attractive vertical design and sports a Hi-Speed USB 2.0 interface for fast and easy connection to Windows XP/2000 PCs.This drive doesn’t support iDVD.
Box was open but everything is in original packaging and its in the original box. $40
