Sony wega KV-24FS120 flat screen tv. Screen itself measures 24" from corner to corner. No problems. $40. Located in Elmwood Village area of Buffalo. I live here again so this is available whenever.
Sony’s KV-24FS120 24-inch WEGA TV is no pushover. Its FD Trinitron tube delivers strong image accuracy, wide viewing angles, outstanding contrast, and impressive corner-to-corner detail. The visually flat FD Trinitron tube minimizes annoying glare from light sources, which enhances contrast. Corner-to-corner details are rendered more accurately because images aren’t distorted by a curved screen. Squares look square, straight lines appear straight, and circles are circular.
Velocity modulation (selectable: off, high, low) improves the definition at picture edges, creating sharper images by slowing the CRT (cathode-ray tube) beam’s horizontal scanning during demanding work–say, when rendering transitions from light to dark parts of an image–and speeding it up when scanning easily rendered sections, like broad dark areas. The set’s digital comb filter further enhances resolution by removing blurred edges between colors and reducing dot crawl (tiny, moving dots of color along a sharp color separation in a vertical line, as in a depiction of a character’s striped T-shirt).
Top-of-the-line component-video inputs minimize digital and line-scan artifacts from compatible video sources, while standard composite- and S-video inputs accommodate all DVD players. You can choose between a set of rear AV inputs and a set of front AV inputs for extra convenience when hooking up a camcorder or gaming console. You may also label the set’s video inputs and channels for easy selection.
The set produces stereo audio with 10 watts per channel. Its Dynamic Picture Processor circuitry maintains image detail in the very bright and dark areas of each scene, while vertical aperture compensation sharpens picture definition and edge detail on the vertical plane). Other features include tilt correction and Trinitone color temperature control.
Using Sony’s channel-fix feature, you can select a specific TV channel (3, for example) for cable box reception, then subsequently control a compatible cable box via the TV’s remote without inadvertently changing the TV from your designated input channel. Favorite channel offers one-button access to the last 8 channels you’ve tuned (auto) or the last 8 favorites that you’ve preset (manual).
